585,949 active members*
4,381 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > Replace old CRT monitor to LCD monitor
Results 1 to 10 of 10
    Hi!
    I successfull connected LCD monitor to my old Okuma LC30 with OSP5000L.
    I used this card:
    New Arcade Game RGB CGA EGA YUV to VGA HD Video Converter Board HD9800 GBS8200 | eBay
    Now I am searching the new monitor for it.
    What will be the best LED monitor for Okuma?
    Quote Originally Posted by =aike= View Post
    Hi!
    I used this card:
    Can you share the pinout? I have the same machine, the connector is a 20 pin male IDC and I am having trouble making it work. A pic or sketch will help a lot
    jolulank
    I will send you it next week.
    My electronics are in vocation now.
    Jan 2007
    37
    Email this guy for an easy drop in LCD Monitor. Adam Verin <[email protected]> part number is ML121CN5000; <$1400.
    TKBuisan
    Apr 2015
    Hi would you please share the pin out for the old 20 pin okuma crt connector? Thank you.
    dekbanpong
    [email protected]
    Dec 2015
    Re: Replace old CRT monitor to LCD monitor
    Hi .New to the forum .I also have a OSP 5000l-g that requires a new monitor. Did anyone share the pin out?
    None had shared the pin (:
    Dec 2015
    Do have a schematic?
    No, I have no CRT schematic.
    Red face Re: Replace old CRT monitor to LCD monitor- Okuma OSP5000 OSP5020 and OSP7000
    Okuma OSP5000 OSP5020 and OSP7000 CRT Monitor is a 12 inch color crt display.
    Replacement Specifications type: Okuma OSP5000 OSP5020 and OSP7000 Color LCD, industrial LCD panel, 20 pin signal connector, AC100-240V power supply , separate OSD keys,easy to mount and setup.
    https://en.elongshine.com/product-de...olour-monitor/
    Okuma OSP5000 and OSP5020 CRT Monitor is a 12 inch monochrome crt display.
    Replacement Specifications type: Okuma OSP5000 OSP5020 mono LCD, industrial LCD panel, 10 pin signal connector, AC100-240V power supply , separate OSD keys,easy to mount and setup.
    Okuma 5000 5020 mono Monitor
    https://en.elongshine.com/product-de...-mono-monitor/
  1. LCD Monitor
    By Dyad1 in forum Fadal
    Last Post: 06-25-2022, 07:20 AM
  2. Looking for info on how to replace my CRT monitor.
    By WmGuildenstern in forum Fadal
    Last Post: 12-09-2012, 04:31 PM
  3. Bad Monitor
    By eded59 in forum Fanuc
    Last Post: 10-21-2010, 08:44 PM
  4. HL-2 monitor very dim
    By 11toma in forum Haas Lathes
    Last Post: 08-15-2009, 04:17 AM
  5. monitor
    By rusticr6 in forum Haas Lathes
    Last Post: 10-25-2007, 01:06 AM
