585,602 active members*
3,553 visitors online*
    Oct 2011
    16
    Mazak QT 15 Alarm 14 Drive alarm z axis
    Hello all!
    I seem to have an issue with my mazak. This morning the Z axis started acting up. Doesn't matter if its moving or not, but every so often it will make a horrible grinding noise and the load meter will register. It got progressively worse until it finally alarmed out.
    Any suggestions?
    24220
    Counter balance?
    Try it with the motor disconnected from load.
    Al.
    Albert E.
    Oct 2011
    16
    I'm not sure what you mean by counter balance.
    I talked to Mazak, and they walked me through some things. Turns out the encoders are the same for x and z, so I swapped them. Bet unfortunately the problem remains at Z. Now it looks like it's either the motor or the drive.
    Oct 2011
    16
    Turns out it was the drive. <sigh> So, in three to five business days and $2100 Mitsubishi will have it fixed.
    The day before it crapped out, there was a thunderstorm. I broke my own rule about shutting everything down and worked through the storm. At one point everything dimmed - lights, lathe rpm's, etc. I bet thats what took it out.
  1. Replies: 27
    Last Post: 02-09-2022, 05:10 PM
  2. Replies: 2
    Last Post: 11-24-2018, 09:15 PM
  3. VF-6 DC drive over current alarm z axis
    By meadowtech in forum Haas Mills
    Last Post: 02-25-2013, 05:26 PM
  4. Alarm #37 on 4th axis drive.
    By EliseoMonteverd in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 12-22-2010, 04:36 PM
  5. Mazak H15 / 4th Axis Alarm
    By Karsue in forum DNC Problems and Solutions
    Last Post: 02-22-2010, 01:49 AM
