585,761 active members*
4,080 visitors online*
IndustryArena Forum > Community Club House > Yasnac MX2 FEEDRATE
    Jul 2013
    4
    Yasnac MX2 FEEDRATE
    I have a Mori Seiki MV 45/40 Mill w/MX2 control. I am needing to program a feedrate less than 1.0. However, the machine will not respond leaving me to dial it back at the control. Does anyone know if there is a parameter to allow programming a lower than 1.0 feedrate, for example (F.75).
    Greg
    Apr 2009
    24
    If I'm correct MV45/40 is Milling Machine ( Machining Center)
    So, Milling Machine will use feed rate value in Feed per Minute (Inch or MM) not Feed per Revolution as the turning machine.
    That way you can't use F0.75 as you mention. ( 0.75 mm or 0.75 inch per minute will too slow for cutting tool in Milling )
  1. Feedrate override vs programming a faster feedrate?
    By Zeppelin1007 in forum Mach Software (ArtSoft software)
    Last Post: 01-11-2013, 10:38 PM
  2. Replies: 4
    Last Post: 02-15-2012, 04:52 PM
  3. Plunge feedrate
    By gbjets in forum CamBam
    Last Post: 01-04-2011, 12:43 AM
  4. G02, G03 Feedrate !!!!!
    By usb in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 09-16-2008, 01:19 AM
  5. adaptive feedrate
    By camtd in forum EdgeCam
    Last Post: 11-13-2006, 11:59 PM
