585,670 active members*
4,550 visitors online*
    Feb 2012
    13
    Matsuura MC 760 VX Power Issue
    Hi all, I have a Matsuura Mill. MC 760 VX. It's been running like a champ as long as I have had it, but the last week or so we have had problems with the Chiller for the Spindle and the machine will stop working. We end up powering it down for a little then back up and it works fine. We tried adding more freon coolant but it wouldn't take. This morning I came in to start up the machine and I turned the main power on in the back, then once I hit the power on at the controls it just shuts down. I checked around for any breakers that I could find, or any other issues that I could find visually (though I know I don't know them all) and I couldn't find any issues. So I gave it another try, and same issue. Then I went and check the alarms LEDs in the power and the axis control boxes and none popped up. I would appreciate any help or insight! I want to get back to making parts!
    Sep 2021
    Re: Matsuura MC 760 VX Power Issue
    Tengo un problema similar mi maquina la acabo de adquirir al conectar con el boton de para se emegencia prende la pantalla pero lo quito y se apaga verifique el aceite del usillo y no trae aceite ese pudiera ser el problema
  1. Matsuura Tool Change Issue
    By wsm in forum Uncategorised MetalWorking Machines
    Last Post: 10-19-2014, 12:52 AM
  2. BMC 20 power up issue
    By Rulunney in forum HURCO
    Last Post: 11-28-2012, 09:03 AM
  3. Methods and Matsuura Announce New US Matsuura Product Manager
    By Pam Laite in forum News Announcements
    Last Post: 08-30-2011, 05:27 PM
  4. matsuura mx1- laptop issue
    By DDCIGEO in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 02-26-2008, 05:41 PM
  5. Power down issue.
    By elaganis in forum Haas Mills
    Last Post: 06-28-2007, 12:44 AM
