585,748 active members*
3,613 visitors online*
    Oct 2005
    186
    Engraving in foam question
    I was thinking about engraving in a block of foam where letters are left in a box. Anyways, do I need to use a certain type of foam such as the density? Or can I use plain ole styrofoam? I saw some sheets on ebay 2" thick that seemed cheap.
    And is there something i can spray on the foam when done to make it stronger?
    Thanks!
    Warren
    LetterCAM CNC Software
    http://www.LetterCAM.com
    Jun 2005
    40
    Mar 2006
    1625
    use a closed cell foam(if it floats it's closed) open cell will retain water
