585,888 active members*
4,134 visitors online*
    Sep 2004
    5
    GdTool settings...
    Just to make sure I understand everything... If I have a dc servo motor with these specs:
    Terminal voltage: 90 VDC
    Continuous current: 7.5A
    Peak current: 30 A
    Resistance: 0.85 ohm
    Inductance: 2.35mh
    What are the right values in Gdtool for: Maximum peak current, maximum continous current?
    Sep 2009
    5
    Parallel DC mode?
    Sep 2004
    5
    I don't know much about electric...I usually need a drawing if I have to do electrical work, or an example to follow. For the moment I have one servo per drive...and settings is : Maximum peak current: 30000, maximum continous current: 7500, don't know if it's right??? BTW...I write wrong in first post...the servo is 70 VDC...not 90
    I would like the manual to have more examples so a novice like me also could get it
    Sep 2004
    1207
    Yes, 30000 and 7500 are correct values to be entered in GDtool.
    Also you need to wire motor to "parallel outputs" way and choose the corresponding motor mode from GDtool. Otherwise peak current will be limited to 20A.
  1. GDtool Communication Problems
    By MetalStorm in forum CNC Machine Related Electronics
    Last Post: 03-04-2013, 11:20 PM
  2. more GDTool communication issues
    By daedalus in forum CNC Machine Related Electronics
    Last Post: 03-04-2013, 08:49 PM
  3. Sneak peek to the new GDtool 3
    By Xerxes in forum CNC Machine Related Electronics
    Last Post: 04-01-2012, 06:30 AM
  4. Mach3 CV settings vs. G-100 Plugin CV settings
    By Bfarn in forum Machines running Mach Software
    Last Post: 12-17-2008, 05:45 PM
  5. dnc settings
    By jamesr in forum Fanuc
    Last Post: 02-02-2006, 09:13 PM
