585,764 active members*
4,126 visitors online*
Thread: LPT Pinout
    May 2013
    Question LPT Pinout
    Hey i have bought a CNC Control Set with motors (?Free Ship?3 Axis Cnc Nema17 Wantai stepper motor 4000g.cm 3D 42BYGHW609,DQ420MA | eBay) for my selfmade Cnc.
    So i build it up like in documentation, and set pins and ports in mach3, but nothing happens.
    When i try to close emergency or any other switch mach3 dont get anything! But when I took off the lpt plug and bridge
    ground and pins i realised, there's sth wrong. In mach3 i set XLimit Pin 10, YLimit Pin 11, ZLimit Pin 12 and EStop Pin 13, but on the Plug XLimit is Pin 5, YLimit Pin 6 , ZLimit Pin 4 and EStop Pin 3
    That means the Pins are
    Mach3 Lpt
    10 5
    11 6
    12 4
    13 3
    15 2
    How can these Pinouts so wrong
    Apr 2003
    550
    Are you sure you have a good cable. You need a pip to pin cable which isn't a common as you think. Make sure your cable is correct..
  1. nsk em cn2 pinout
    By dim371 in forum Servo Motors / Drives
    Last Post: 03-05-2019, 12:28 AM
  2. Heidenhain MPG pinout
    By botha.y in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 03-07-2012, 10:59 PM
  3. USB adaptor pinout
    By fomaz in forum CNC Machine Related Electronics
    Last Post: 05-25-2011, 07:09 AM
  4. MV Jr Serial Pinout
    By andyhol in forum Uncategorised MetalWorking Machines
    Last Post: 10-30-2009, 11:11 PM
  5. #23-305-DS8A Pinout
    By Richie800 in forum Hobbycnc (Products)
    Last Post: 11-15-2007, 09:11 PM
