585,759 active members*
4,350 visitors online*
IndustryArena Forum > MetalWorking Machines > Uncategorised MetalWorking Machines > Vectrax CNC mill with servo motors and dead computer looking for help to upgrade/repa
    Apr 2013
    I recently purchaced a used Vectrax cnc mill with an old computer which has become very sporatic since the move. I am thinking that I should upgrade to a new computer and control system but need help/advice on how to do it and costs or best place to call. I contacted gecko drives to see if I could use theirs but the tech said they didn't have what I needed w/o a lot of work and didn't recommend it. The computer will turn on some times and the screen usually will flicker once it is going. I took it to several computer repair shops and they basically said no way so here I am.
    It is a 3 axis cnc mill with 5 tpi ballscrews, with brushed dc servo motors model mt30m4-38, INFO FROM THE MOTORS: c.stall 26 lb/in @8.6 A, 3700 max RPM 140V 47A
    I am looking to do some prototyping work mainly with the possibility of some small production runs but primarily prototyping.
    Thanks so much for any help or advice you can give.
    Mark
    24220
    What is the vintage of the PC? ISA bus? what is the controlling element? motion card? if so what make?
    You may be able to revive it, maybe the reason Gecko could not help is it is ±10vdc analogue control.
    Al.
    Albert E.
    Apr 2013
    I believe the computer was late 80's like 88/89 with an isa card on the computer which I was told they don't make any more.
    Gecko could not help because they did not support the servo motors that were on there, too big for what they handle according to the tech. Tech said would have to replace the servos with something much smaller and if I went the stepper route I would have to make new brackets and quite a bit of hardware and I'm not really interested in that route.
    24220
    If you post the name/part No. of the card and what type of present servo drives, probably analogue input?
    It may be possible to suggest further, otherwise it is hard without all the details?
    Al.
    Albert E.
  1. question on computer upgrade
    By snkdriver in forum Post Processors for MC
    Last Post: 07-05-2012, 04:15 PM
  2. Is my Servo amplifier dead?
    By padobranac in forum Fanuc
    Last Post: 02-02-2012, 12:40 PM
  3. Where to buy servo motors for my bp mill?
    By CATCH22 in forum Servo Motors / Drives
    Last Post: 04-07-2009, 12:39 PM
  4. Servo motors for CNC ready 3/1 and Mill drill
    By Dan Mauch in forum News Announcements
    Last Post: 03-26-2006, 03:37 AM
