Hello excuse if you disorder, i have a Partner Milltronics infra-VM16 with centurion I also
am a problem similar to yours, in the sense that i think has the memory of the ISA card (to be exact the one that communicates with the axis tab) corrupt.
TO me when I turn on the machine doesn't load the system, and i always do the setup from dos the same to be able to access it, and doing the setup i found 720 kb 400 kb corrupted.
The problem is still there every time I turn off the machine, which among other things does not work and it gives me error 450
there is a provisional system for your use? I think that the problem is the file pfile.dat now lost.
Someone has the file in question with the configuration compatible with the following machine?
The machine is this: Partner V16 with Milltronics Centurion VI
Thanks to the people who i know illuminate..
