Sorry, but I need some help. I want to use a 5V signal to enable the drive after my controller powers on. I was wondering how to configure this in GD tool as well as the wiring configuration. Currently on the command (CMD) connector I only have pins 10, 15, and 16 hooked up.
Pin 15 and 16 are my analog inputs to my control. Pin 10 is what I thought should be hooked up to the 5v reference signal for the drive enable, but I can't get it to work.
So my question is, what am I doing wrong? How can I get this to work. Do I need extra wires going somewhere? Can someone please tell me what I need to do in the GDtool to configure it as well. I read the manual, but it isn't clear as far as "For pin 10, if high, disable drive"... Sorry, I'm new to all of this.
I would also like to have an EStop hooked up as well to disable the drives, but first things first.
Also, I have another question - Is there a way to use this drive as a VFD? I have about 7 of these drives, and I currently have a spindle, but no VFD. I was wondering if I could use this for the spindle, at least to test it out before purchasing a VFD.
Dave
