I am currently designing a very sturdy CNC with a moving gantry.
Basically it will be all steel soldered construction, meter by meter table size, RG 30 size Hiwin Roller bearing slides on X Y, rack and pinion drives - possibly CNC Routerparts with 960 oz-in Nema 34 Motor.
Now the funny part. Instead of spindle i will mount a bench sand rammer /tamper/ with steel head and i will use it to form a wok like object from 1.2mm soft steel sheet 60 cm in diameter and 12-14cm in depth. Obviously any sturdy machine will cope with Incremental sheet forming using non vibrating tool with a small radius. But for reasons too complicated to explain, i need it hammered.
I design it not being cheap on bearings, bearing blocks foot distances, rail length and and metal i use for the table and the gantry.
So i am not worried about vibrations and sturdiness, nor i am worried about the roller bearings/ ok , may be a little, but not so much to change them in the design to plain Frelon open supported round shaft bearings/. The metal sheet is really soft and shallow passes or smaller radius head of the hammer can cure eventual problems
I am worried about how i make the Z resistant to up and down vibration from the pneumatic hammer/800-1200 hits per minute/. I mean how to move the Z? Obviously there has to be no clunky backslash , it had to be firm. I am also not worried about precision, eventual belt stretch for example can be compensated via pass depth and material springiness.
So i thought of 2 synchronously driven ballscrews with 2 nuts each to eliminate backslash and make it sturdy. Belt driven, where the belt absorbs a bit the shock, but how to power it, i will need a big extra wheel geared to the motor to transmit enough force to hold it in its place. What about roller chain with a similar construction?
Any help and ideas?
To understand it better here is how the machine will look and what it should do, though with a smaller hammer and smaller head, but you get the idea. Dont misjudge it from the drawing, i am making a small tank, all steel parts you see are 10mm thick at least:
