585,981 active members*
4,288 visitors online*
IndustryArena Forum > MetalWorking Machines > Bridgeport Machines > Bridgeport / Hardinge Mills > Bridgeport Series II Special with Anilam 3300MK 3axis controller
    Jul 2013
    Hello everyone. This is all new to me so hopefully won't waste anyone's time. I have just purchased a Bridgeport Series II Special milling machine fitted with an Anilam 3 axis controller 3300MK. Everything is like brand new and the machine was fully operational when demonstrated. After shipping and installation into my premises I am getting an error message when I power it up. ERROR... CANNOT DETECT MOTION CONTROL BOARD. I get a prompt to continue, press F10. This does nothing. I have tried pressing clear and enter. I have check the E-stop and servo reset etc and check all the limits. I have tried all these steps in manual and auto mode. I can't manually operate the spindle or any of the servos. I don't know where to go to next. Can anyone help?
    Regards Ray
    Aug 2010
    190
    Open the side cabinet, and check you connections
    Jul 2013
    Thank you. I had checked and re checked every plug , circuit board connection and power.What I have found out is that I had too low a voltage to the hard drive. Supposed to be minimum 5.1V and I only had 4V. There is an adjustment to rectify this and to my relief it is now working.
    Regards Ray
    Apr 2013
    40
    Also make sure your 12v is good as well. If you don't know where to check it, I have the sheet from Anilam to show you how.
  1. Anilam 3300MK
    By Dave Rothermel in forum DNC Problems and Solutions
    Last Post: 05-07-2012, 11:06 PM
  2. Anilam 3300MK
    By Buried in forum DNC Problems and Solutions
    Last Post: 05-02-2012, 05:36 PM
  3. Replies: 0
    Last Post: 12-27-2011, 07:14 PM
  4. Need post processor for Anilam 3300MK controller
    By kmgcmk in forum News Announcements
    Last Post: 12-07-2011, 05:46 PM
  5. Anilam 3300mk
    By klingnic in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 04-18-2011, 02:42 AM
