A now ex-employee "quit" pulled out a t-nut too far and spun the chuck into the tool setter under power in low gear knocking the tool setter WAY out of wack, now it's my job to realign it, I first off loosened off the screws that hold it to the machine and adjusted it so it would fit back in its home tube, but now the tool tip only touches on the very edge of the setting tip, I know how to adjust the size the tool cuts and I've got it cutting within .001 so it works fine but I can't figure out how to get the tool centered on the tool setter tip, no matter how I adjust the 4 screws that hold it to the machine it still does not affect the contact point much, is there an internal stop that can be adjusted to raise or lower how far the setter head comes down? It goes down too far is the problem. I included a few pics to show the problem, one pic is of the tool setter and the other is how the tool tip touches.Thanks for any advice.
