Originally Posted by
haasab
Hello
I check the power ... the power comes in . I find that in programing book. Please read. I thing this is the problem.
Main contactor K1 is used to turn the control on and off. The POWER ON switch applies power to the coil of
K1 and after it is energized, auxiliary contacts on K1 continues to apply power to the coil. The POWER OFF
switch on the front panel will always remove power from this contactor.
When the main contactor is off, the only power used by the control is supplied through two ½ amp fuses to the
circuit that activates the contactor. An overvoltage or lightning strike will blow these fuses and shut off the main
contactor.
The power to operate the main contactor is supplied from a 24V AC control transformer that is primary fused at
½ amp. This ensures that the only circuit powered when the machine is turned off is this transformer and only
low voltage is present at the front panel on/off switches.
Sow where are those two fuses ½ amp ?
Thank your for you hellp and time
