585,741 active members*
5,059 visitors online*
IndustryArena Forum > CAM Software > EdgeCam > Flipping the part in Edgecam
Results 1 to 9 of 9
    Mar 2013
    24
    Hello all,
    I'm new to using Edgecam. Can anyone give me tips on how to flip the part in Edgecam; so after milling one side, flip it over to mill the other side without starting a whole new document? I was kind of thrown into using Edgecam on a self-learn track and stuck on this... I created a new CPL for the other side but when I click over to Manufacturing Mode, the tool is still oriented towards the original side.
    Any tips or advice would be greatly appreciated. Thanks!
    Mar 2012
    16
    You may have already found this on the screen, but when in manufacturing mode there is a "move" tab in the top of the toolbar. If you click on that a menu will drop down. One of the items will be "index". That will be where you can rotate the tool around to the other CPL. I think this is what you were looking for.
    Kelly
    Mar 2013
    24
    Thanks, Kelly! I think we're on the right track with this--did not know about the MOVE tab before. Problem is when I do this, it doesn't appear to rotate the tool, just shifts it over over to that CPL; which I had originally oriented correctly but now it's Z axis is pointing the same direction as the original side... is there a setting I'm not choose correctly? I had my CPL's oriented correctly for both sides accordingly but the INDEX just moves it over on the same plane. Any ideas?
    Quote Originally Posted by kbarnett View Post
    Kelly
    Jun 2008
    125
    Hi guys,
    It could depend on whether your post is set up to index in the correct way. In theory if you create your cpl correctly then a move index should always index there.
    See my video to see how I did this.....
    2013-08-03_0659 - Meegers's library
    Mark
    daveallen Guest
    I havn't tried it but one would think that you could just copy the model to another layer and flip it over and work off that model.
    Sep 2008
    24
    You can do it this way
    Align your part/first side with Top/G54 CPL.
    Create a new CPL G55.
    Geometry Create CPL.Name G55 Origin box marked.
    press ok.
    Select new origin for Cpl. Press x200 y0z0. Now you have a new CPL called G55.
    Edit. Transform Translate. X200 Y0 z0. Repeats 1.Put mark in Copy. Ok.
    Now you can align Side 2 with your CPL G55.
    Feature Find Side 1 with Top CPL active and Side 2 with G55 active.
    Use Top Cpl when you go to Manufacture Mode.
    When you change to Side 2. Index. Name G55
    Attachment 225518Attachment 225520
    Oct 2011
    4
    Why not starting a new manufacturing sequence using the new cpl ?
    Isn´t that the right way if you clamp the part another way ?
    May 2004
    142
    Re: Flipping the part in Edgecam
    I agree with Mimer... copy and rotate the model/ create additional cpls/ new sequence per op
    DONT MIND MY SPELLING ... IM JUST A MASHINIST
    Nov 2019
    On this point, if you do set up a few new sequences, is there a way to rearrange the order of the sequences?
  1. Dowels and Part Flipping
    By JMBush01 in forum Work Fixtures / Hold-Down Solutions
    Last Post: 11-04-2013, 09:24 PM
  2. General question about flipping a part
    By cobrakai in forum Tormach Personal CNC Mill
    Last Post: 09-18-2013, 05:31 PM
  3. Help with flipping a part
    By kevinro in forum Tormach Personal CNC Mill
    Last Post: 02-01-2013, 07:19 PM
  4. Flipping part, HELP!
    By Telle in forum Mastercam
    Last Post: 12-04-2007, 05:45 PM
  5. Need techniques for flipping part, continuing
    By originator in forum MetalWork Discussion
    Last Post: 11-15-2006, 01:19 AM
