585,975 active members*
5,008 visitors online*
IndustryArena Forum > WoodWorking > WoodWorking Topics > Feedrate of endmill in 1/2" ply
    Aug 2013
    14
    I recently discovered a FabLab near to where I live, and have been visiting it for the last few weeks to make a project.
    However i am not sure of the best cutting speeds for the materials i am using. And as a result it took 2 hours to cut a 2' x 3' piece of 1/2" ply.
    I am using a ShopBot, with a 3Kw router. I need to cut the design into 1/2" ply with a 1/4" bit. I have access to a 1/4" 2 flute router bit and a 1/4" Down-Cut Spiral Router Cutter.
    currently the cutting settings are:
    pass depth - 0.125 (inch) (3mm)
    Spindle speed - 12000 (rpm)
    Feed rate - 100.0 (inch/min) (60mm/sec)
    Plunge rate - 30.0 (inch/min) (20mm/sec)
    I am also using a 1"/25mm ramp on all cuts.
    Please can you suggest the best router bit to use, and the best settings for the control of the router. Any advice is greatly appreciated.
    -Ben
    I'd cut it in 3 passes of .166
    Ramp at 150ipm, and cut at 300ipm and 16,000-18,000 rpm. The 2 flute downcut should give you the best results.
    What kind of plywood is it
    Aug 2013
    14
    I am not exactly sure which plywood it is. It is lightweight, so I would assume that it is Softwood plywood, as its quite lightweight, and splinters quite easily. (it may be spruce, pine, or fir)
    Thank you for your recommendations, I will give them a try over the weekend. (it takes the project from an expected 4 hours down to 1 hour 30)
    the next question I have is, what plunge rate and RPM would you recommend for a 1/4" and a 1/2" drill in plywood?
    If the drill bit will be in the spindle, then spin it as slow as you can and drill as fast as you can. For the 1/4" holes, you'll probably get much cleaner holes by peck drilling with the router bit.
    Jan 2006
    2985
    And you could interpolate the 1/2" hole so you don't need a tool change. A 1/2" jobbers length drill at 18,000 RPM would scare me.
  1. Cutting Parameters for 1" Endmill Interpolating 2" Hole
    By daedalus0x1a4 in forum Material Machining Solutions
    Last Post: 11-08-2011, 12:29 AM
  2. Feedrate for 0.02" precise bit on ebony ?
    By rdpdo in forum WoodWorking Topics
    Last Post: 05-15-2010, 04:29 PM
  3. Dremel with 1/8" endmill - what cutting speeds for 1/2" MDF
    By HankMcSpank in forum DIY CNC Router Table Machines
    Last Post: 06-01-2009, 04:18 PM
  4. modifying Carbide endmill shanks"cutting them shorter"
    By kojack in forum Metalworking- / Woodworking Tooling / Manual Machining
    Last Post: 05-26-2009, 05:08 PM
  5. "Acrylic" Carbide Endmill ?
    By yngndrw in forum MetalWork Discussion
    Last Post: 03-13-2009, 01:43 AM
