585,875 active members*
3,934 visitors online*
IndustryArena Forum > CAM Software > Vectric > PhotoVCarve and VCarve Pro > How to slice large carving on an medium size table?
    Oct 2006
    205
    HI,
    My cutting area is only 24x40 and I have a carving that is 36x36inches.
    I purchased a complete 3d model from VectorArt3d.com that can be scaled to my desired size.
    Is there anyway that I can cut this carving in 2 pieces?
    Please keep in mind that this is a 3d model.
    Thank you all in advance.
    Rod
    San Francisco
    Apr 2004
    5737
    I suppose you could do that. Start with two pieces of wood 24 x 36 and carve one side on one and the other side on the other. Leave some overlap, so you can slice off the extra material and glue the two pieces together along the joint. If you've got a wood jointer, you can cut it a little oversize on the table saw and shave down the edge until it matches precisely (as long as you don't screw up the angle).
    Andrew Werby
    www.computersculpture.com
    If you're using Aspire (you posted this in the Vectric Forum), use the Toolpath Tiling feature.
    Oct 2006
    205
    Ger,
    I never thought to look into the Toolpath tiling feature. Didn't know it existed.
    Sorry for the double post. I would have posted to the Vectric forum first, but my new registration to the forum was not approved right away.
    Rod
    I meant that you posted in the Vectric section here, so I assumed you were using Aspire, but you didn't mention it.
  1. Replies: 1
    Last Post: 05-22-2012, 02:58 AM
  2. Heavy large scale gantry mill/router/3d carving 5 axis build
    By Tristar500 in forum DIY CNC Router Table Machines
    Last Post: 03-18-2010, 12:07 PM
  3. Large size laser cutting machine DC-1324
    By mandyfang2006 in forum News Announcements
    Last Post: 01-13-2009, 10:14 AM
  4. large size aluminium(6061) machining
    By sharathchandar in forum MetalWork Discussion
    Last Post: 07-23-2008, 02:57 AM
  5. WTB: Small medium or large sized CNC machine in Alberta
    By djnbig in forum Uncategorised MetalWorking Machines
    Last Post: 05-20-2008, 09:06 AM
