585,996 active members*
4,141 visitors online*
IndustryArena Forum > CAM Software > Uncategorised CAM Discussion > Sinusoidal surface diamond turing
Results 1 to 2 of 2
    Mar 2017
    5
    Hello,
    My task is to create a turning simulation of the object shown in the attachment and then machine the object. The object will be machined on 3 axis lathe, x,z,c. The lathe is single point diamond turning machine – Nanotech 350 upl. I am looking for a proper software which will allow me to generate g-code and simulate the machining process (toolpath simulations). I was trying to do the simulation in Catia and NX but I couldn’t do it because of sinusoidal surface and software constrains. Any good proposition of CAM software that will help me with my task will be very valuable to me.
    However, if there is a way to generate the turning program and simulation on Catia or NX, please go ahead and describe a way in which I could do it. Thanks, in advance for your reply.
    Here are some links that show videos of the process I will need to use for this part:
    https://www.youtube.com/watch?v=aQyG8aOm7yI
    https://www.youtube.com/watch?v=MUgL9vnATF8
    Thanks, Lukasz
    Feb 2009
    6028
    Re: Sinusoidal surface diamond turing
    Call moore directly., ive seen them and precitech do this. One of them, can't remember which one actually had some software in the control to do just that type of part.
    Sent from my SM-T813 using Tapatalk
  1. Diamond cut end mill surface finish
    By geroge in forum Hobby Discussion
    Last Post: 05-01-2015, 12:32 AM
  2. Turing tools holder with carbide inserts
    By Sino-waterjet in forum News Announcements
    Last Post: 07-12-2012, 02:28 PM
  3. tap cycle on turing center
    By hackmeister in forum G-Code Programing
    Last Post: 01-30-2010, 05:24 AM
  4. sinusoidal question (probably to Al the man)
    By JasonCampbell in forum Servo Motors / Drives
    Last Post: 09-29-2007, 07:20 PM
  5. Surface Grinder Wheel - Diamond Dresser question?
    By widgitmaster in forum MetalWork Discussion
    Last Post: 06-27-2006, 06:00 AM
