585,978 active members*
4,426 visitors online*
IndustryArena Forum > Community Club House > Mitsubishi Meldas M64 Port 0
    Aug 2013
    13
    Hello, everyone!
    I'm currently working on repairing a box-moving robot, which uses a CNC Mitsubishi Meldas M64 to control it's movements.
    As I've seen around here, my initial problem was quite typical. The Li-On battery went down, and therefore a large number of programs and parameters was lost.
    I spent three days in learning how to back-up the remaining data, formatting, and reinstalling everything via RS232 serial communication. (I used the Hercules software, a regular multi-communications one).
    My problem is this:
    While making the above mentioned operations (format, backup,etc.) I used the original configuration for IN/OUT devices: Port 0, Device:0 (Both in Outputting and Inputing data).
    Then, I accidentaly changed the port number to 2. Since then, It was impossible for me to establish communication again.
    Whenever I try to set the port to 0 again, I get the code: "E02 - Data Over", meaning I'm trying to set an out-of-range parameter.
    Does anybody know how to reset the port back to 0?
    Do I need to format everything again?
    Thanks in advance for taking the time to read my post.
    Regards
    Martín
    Aug 2013
    13
    NEED HELP! Mitsubishi Meldas M64
    Perhaps formatting will restore my settings. Does anybody know that?
    The problem is, that if I choose to format and the ports remain at 2, then I'll be no longer able to load the programs again...
    Thks in advance
    Martín
    Aug 2013
    13
    I've used the Hercules software. Does anybody know if using ConnectCNC is better? Or if it makes any difference at all? For what I've read in the forum, it has quite a number of problems.
    I believe that changing the parameters in the PC side won't have any effect, because "Port 0" is the outside port of the CNC itself. (I have an HR211 expansion card).
    I would appreciate any opinions on this. Thanks
    Martín
  1. Mitsubishi Meldas L3
    By hutch07 in forum MetalWork Discussion
    Last Post: 07-30-2022, 07:42 AM
  2. Mitsubishi Meldas 60S
    By BKCOM in forum Mitsubishi controls
    Last Post: 11-28-2016, 03:59 PM
  3. Mitsubishi Meldas 50 (m50)
    By ssakas in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 05-26-2014, 08:17 PM
  4. Help w mitsubishi/meldas 500
    By Gpl625 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 10-04-2011, 05:27 AM
