It depends on how precise control you need and how much automation?
If you are welding manually then often a foot switch is used, if you want it automatic then it is usually simple to control the table and welding start/stop.
If you want the kind of automation where you load a part and press a button, then the start and stop position is usually a precise control, i.e. servo/stepper etc.
Al.
Albert E.
