585,749 active members*
3,660 visitors online*
IndustryArena Forum > MetalWorking > Casting Metals > Casting compound - looking for alternatives - any suggestions.
Results 1 to 6 of 6
    May 2003
    323
    Hello
    Are there any alternative casting compounds that are not as expensive as this one.
    Apr 2004
    5734
    May 2003
    323
    Thank you for posting.
    I need to metion where I am using this compound.
    Each time I use about a spoonful.
    It needs to retain shape when removed from cavities or holes.
    I machine parts and sometimes I need take an impression of the features to measure radii and angles on optical comparator.
    Jun 2013
    1041
    Try miapoxy.com formerly called hobbycast. They have decent prices and its available in many set times.
    Ben
    May 2003
    323
    Quote Originally Posted by bhurts View Post
    Ben
    Thank you Ben
    Jul 2009
    419
    Mostly forgotten but alginate may work, as well as gelatine.
    Will not last forever but both have been used in stead of where rubber is mostly used these days.
    If you store it well i think gelatine can be reused by heating it again.
    Sven
    http://www.puresven.com/?q=building-cnc-router
  1. Manual Threading with Compound vs CNC without Compound
    By frostheave in forum MetalWork Discussion
    Last Post: 07-14-2013, 09:33 PM
  2. MFG.com alternatives
    By blackdoggy in forum MetalWork Discussion
    Last Post: 06-25-2008, 10:52 PM
  3. what is a compound?
    By diluded000 in forum MetalWork Discussion
    Last Post: 07-31-2007, 04:35 PM
  4. THC alternatives
    By max_imum2000 in forum Waterjet General Topics
    Last Post: 03-19-2007, 11:23 PM
  5. Enco Compound Slide Milling & Compound Drilling Table
    By 7ofclubs in forum DIY CNC Router Table Machines
    Last Post: 12-24-2006, 05:43 AM
