585,967 active members*
3,903 visitors online*
IndustryArena Forum > CAM Software > Vectric > Cut2D / Cut3D > cut 3d and rotary axis
    Jan 2013
    18
    hello all, i am considering purchasing cut3d and have a few questions. first, can cut3d resize stl images. and second, can i use it to cut a cabriole leg on a rotary axis. i am wanting to buy this 3d image LEG3 - Cabriole Carved Leg for Table - Carver3D and be able to cut on my 4 th axis. im not sure how this works as i am definitely a greenhorn when it comes to this. any input on what i will run in to would be appreciated. thank you so much for your input bill
    Apr 2012
    75
    I can't answer whether Cut3d will do exactly what you're asking, but you can download a trial version good for 30 days. It won't output any code other than for their tutorial parts, but you could see if the desired functionality is in it and I suppose you could simulate the cuts.
    If you haven't already purchased Cut3D, you may want to look at the hobby license of DeskProto. Deskproto has multiple 4 axis toolpaths available.
    However, if you plan on making money from the parts you'll be cutting, you can't use the Hobby license
  1. Replies: 1
    Last Post: 11-17-2015, 07:37 PM
  2. Replies: 1
    Last Post: 06-23-2013, 05:02 AM
  3. Auto align B-axis (rotary axis) using probe
    By pwilson101 in forum Parametric Programing
    Last Post: 02-06-2012, 02:53 AM
  4. Replies: 1
    Last Post: 01-14-2012, 06:22 PM
  5. Tipping rotary haas rotary axis
    By mfpuller in forum Mastercam
    Last Post: 04-04-2011, 04:16 PM
