Dear all,
Trying to cut 6mm plywood i notice the following symptoms:
1) I need to use high power (150W - 180W laser tube at 80%) and low speed (15%) to be able to cut it.
2) The edges of the piece cut are divergent. With this i mean that if i turn the piece arround, the back side looks like scaled up.
I understand by my research that when the laser does not hit the focus lens in the middle the sides of the cut will not be square, but in that case they are all sided to the same direction, and this is not the case.
I have got a meniscus focus lens with f = 2.5' and a laser bean diameter of aprox D = 9.5 mm at the focal lens.
My guess is that with that f and D, the Depth of Focus is too narrow (acording to my research it would be arround DOF = 1.8 mm, and that would be the maximun depth I could get a square cut on any material.
To solve my problem i found two possible solutions, and here is where any advise would be very much appreciated:
1 - Change the focus lens for another one of a larger f value. According to my own calculations, that would be f = 7.5' to get with my current D to a DOF of arround 10 mm; that is my depth target with a square cut.
2 - Buy a beam expander, in my case to reduce D, so as to get a larger DOF. I estimated if I could reduce D to half of it's current value, with a 3.5' focus lens I would reach arround 9 mm of DOF.
Option number 1 seems to be impossible for me, as my head can not go as up as needed to make focus, so I have to make the desition of buying the beam expander or not.
Ok, finally here are my questions:
a) Does the above reasoning (besides the numbers in calculations) sounds logical to you?
b) Does anybody have any experiense with beam expanders?
c) If that is what I need, any idea of where to buy them?
Thank you for your time,
cheers!
Luis
