585,992 active members*
6,011 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Mach Mill > How do I add a 10 seconds delay after starting the spindle
Page 2 of 2 12
Results 21 to 24 of 24
  1. #21
    15362
    Re: How do I add a 10 seconds delay after starting the spindle
    Quote Originally Posted by CitizenOfDreams View Post
    Double-clicking the Start button accidentally is something that can (and does) happen. It can be an operator error, it can be a mouse malfunction, but it is always unintended. There is no reasonable scenario for the operator to intentionally skip the spindle spool-up. So the controller should now allow that to happen.
    Remember good old cars with 5-speed manual transmission? They had a blocking mechanism that prevented you from accidentally shifting from "5" to "R".
    If you wrote some simple code using Mach3 Brains', then you could do what you need with ease, using a mouse to start a machine is a bad idea, thousands do it, nothing beats a physical Button for machine control.
    I surprised that with your electronic skills you don't have a Cycle Start Botton I would not, operate a machine without Cycle Start and Cycle Stop Button
    Your Gear box used a simple ball plunger, some are mechanical some are electrically controlled plungers, this has nothing to do with your computer electronics and using a mouse.
    Mactec54
  2. #22
    Nov 2012
    1267
    I have a very basic LPT port setup, it simply does not have any spare inputs for physical buttons (other than the E-Stop). If or when I upgrade to a better controller, it will have real buttons, real MPG and all the nice stuff.
    My point is, a well designed machine should not obey obviosly erroneous commands - like shifting to "R" at 100 MPH, or plunging the tool into the part at 100 RPM.
  3. #23
    24221
    Although I have loaded Mach to test some things, I have not really used it so I don't know if it is capable of simulating all the G,M,S,T codes the same way a system where the motion is controlled with a motion controller and a separate one for all the machine 'PLC' type codes.
    Similar to standard industrial CNC systems.
    But the advantage of handing over the general (M)achine instructions to PLC type control is, it is left to the CNC motion controller to act on all the motion positioning, servo's etc, if a Machine code is encountered it is a separate controller or process(sor). And the system will wait until the general machine controller completes its task and then issues a FIN(ish) signal to motion controller that the action has completed.
    For example, this is how I have used the Up-to-speed mentioned in post #5, when the program encounters a M or S instruction, for example, The 'PLC' is advised that the S instruction is issued, and waits for the VFD Up-to-Speed output relay to activate, it then sends a FIN(ish) signal back to the motion controller to continue with the motion program.
    Tool changing and other such operations work using the same method.
    Albert E.
  4. #24
    15362
    Yes, but you can also do what you want with the Mach3 Brains, a 1 line 3 block piece of code will stop it from doing what it is doing nothing else needed, like inputs for buttons, just watch some of the Mach3 Brains videos
    This is a starter Video on how too.
    https://www.youtube.com/watch?v=aYqP5-uOzkU&t=603s
    Mactec54
Page 2 of 2 12
  1. spindle shuts off... runs for about 3 seconds then nothing
    By williamsmotower in forum Charter Oak Automation Support Forum
    Last Post: 11-20-2013, 01:55 PM
  2. Spindle startup delay / dwell..
    By kiwichris in forum LinuxCNC (formerly EMC2)
    Last Post: 09-05-2013, 06:07 AM
  3. Spindle delay
    By mkc2 in forum Mach Mill
    Last Post: 01-06-2009, 01:56 PM
  4. mach 3/boss 5 spindle shuts off by itself, will only run a few seconds
    By tom.jelly in forum Bridgeport / Hardinge Mills
    Last Post: 11-25-2008, 07:18 PM
  5. mach 3 spindle delay
    By mike10 in forum Mach Mill
    Last Post: 05-10-2008, 05:50 AM
