584,846 active members*
3,968 visitors online*
    Sep 2009
    1856
    ethernet smooth stepper
    will a ethernet smooth stepper controler, make mach3 run better.
    i ask this becouse the machine i run runs ok but the computer has a brain fart every now and then, that ever wreaks the what ever is being cut or breaks a cutter.
    the machine has g213v and a mb-02v6 break out board running on win xp 32 bit.
    im thinking of getting the smooth stepper just need some input allso can a smooth stepper run on win xp 32 bit, when that computer gives up can i just go out an get a win7 pc 64 or 32 bit and just conect it up.
    http://danielscnc.webs.com/
    being disabled is not a hindrance it gives you attitude
    [SIGPIC][/SIGPIC]
    Nov 2006
    93
    Much better my friend.
    Motors will run smoother and make less noise.
    And you can fine use 1/16 microstep.
    I am using Ethernet SmoothStepper on Windows XP and it runs like a charm.
    You can also use PC based on Inter Atom CPU without any problems.
    Is SmoothStepper worth it? Yes! Every penny!
    Hope that helps.
    Martin
  1. Smooth Stepper Ethernet Board - Mach3
    By mrpackethead in forum X3/SX3/G0619/G0463
    Last Post: 05-09-2013, 02:04 PM
  2. Smooth Stepper or not?
    By tangeray in forum DIY CNC Router Table Machines
    Last Post: 05-07-2013, 10:38 PM
  3. Replies: 1
    Last Post: 10-05-2012, 12:24 PM
  4. Smooth Stepper
    By kingofl337 in forum SmoothStepper Motion Control
    Last Post: 08-19-2011, 03:11 AM
  5. What is a Smooth Stepper and ...
    By gotfdirtball in forum Mach Software (ArtSoft software)
    Last Post: 03-17-2009, 01:43 AM
