585,749 active members*
3,875 visitors online*
    Aug 2013
    Need Help! Y-axis wrong direction
    I have got a used Laser machine HY-690 ºêÔ¶¼¤¹â ¼¤¹â ¼¤¹âµñ¿Ì»ú ¼¤¹âÇиî»ú ¿ÌÕ»ú ÁijÇÊж«²ý¸®ÇøºêÔ¶¼¤¹âÉè± ¸ÓÐÏÞ¹«Ë¾-ÍøÕ¾Ê×Ò³
    I have problems with installing driver/software (RDcam 3.0 no idea about Mainboard) I assumed a mainboard-USB communication problems.(which not detect driver)
    I changed mainboard /control panel MPC6515 and installed lasercut 5.3 communicate Okay with PC can download config.
    But we have got problem with Y axis that moving wrong direction control panel and lasercut either wrong.
    I tried switching wires U,Vand W on Y axis stepper motor drive but no luck.
    Do i need change software syscfg.ini that Im guessing stepper motor mounts opposite way?!
    Nov 2009
    314
    No , you do not need .
    Change the position of A+A- OR B+B- on y axis driver .I mean the wires position . Then power on and test you will see .
    Mary Lee
    XYZ Machinery
  1. Z-axis only turns in ONE direction, anyone know what might be wrong?
    By effimos in forum DIY CNC Router Table Machines
    Last Post: 03-15-2012, 01:20 PM
  2. Z axis backlash that drives the wrong direction
    By Kingjamez in forum Benchtop Machines
    Last Post: 10-05-2010, 03:46 AM
  3. Z axis going in wrong direction
    By erkiwi in forum CNC Machine Related Electronics
    Last Post: 01-20-2010, 11:43 AM
  4. EZ Trak axis running wrong direction
    By spindlenut in forum Bridgeport / Hardinge Mills
    Last Post: 01-14-2010, 05:38 AM
  5. integrex 200 II SY b axis wrong direction
    By smile in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 06-07-2006, 05:09 AM
