I just bought a new 6040 CNC machine.
I got it in 4 days after ordering.
I am using the controller that came with it. I haven't bought a new controller yet.
I got the water pump and spindle working. The pressure blew the large hose off the tube but a simple hose clamp solved that.
There wasn't much in instructions on how to put it together but it only took me 2 hours to figure it out.
The axis are free spinning until I turn the power on then they all lock up which is what the instructions say should happen.
So far, I am happy with the product.
My problem is that I can't get Mach3 to control the axis.
Tried Manual control and nothing happened when clicking X/Y/Z buttons. I think I can hear the axis click once in awhile.
If I run G-Code project, I can hear the axis trying to move. They are clicking but not moving.
If power is off on 6040, Mach3 program Reset says "Press Reset Emergency Mode-Active" and the Reset button is flashing. When power is turned on, the error message goes away and the button stops flashing.
So there is some communication going through the parallel port.
I am not sure any of the foliowing is important since it seems a signal is getting to the axis.
I found the 6040 manual on the Internet and followed those instructions.
In Ports and Pins, I set Kernel Speed to 35000Hz, verified Port #1 enabled and address set to 0x378.
In Control Panel, printer port resource I/O Range set to "0378-037F" and there is a second range "0778-077A". Don't know if this will cause a problem.
In Motor Outputs, I set the following:
Axis Step Pin# Dir Pin# Step Port Dir Port
X 2 3 1 1
Y 4 5 1 1
Z 6 7 1 1
Dir Low Active checked for all three axis.
I applied settings.
Input Signals. Enabled the folowing and set them to:
Signal Port# Pin# ActiveLow
X++ 1 11 checked
X-- 1 11 checked
Y++ 1 12 checked
Y-- 1 12 checked
Z++ 1 13 checked
Z-- 1 13 checked
EStop 1 10 checked
Outut Signals, enable the following:
Enable4-checked, port# 1, Pin# 17
Enable5-checked, port# 1, Pin# 16
Output#1 checked Port# 0, Pin# 0
Applied the settings.
Clicked OK
I sent an email to the company but it is probably night time there.
Does anyone have any ideas?
Greg
