I'm having a very hard time finding a good solution to marking on CNC machined parts - HDPE (white color) and Polypropelyne (white color). These parts are used in industrial machinery and must withstand high temperature sanitation with alcohol, various bleach based cleaners, etc.
I have tried the following thus far and still nothing fits the bill for permanent marking which is clean and easily readable.
- CO2 laser : engraves the HDPE pretty well but you have zero contrast so the mark is hard to read. If I fill the engraving in with color such as dye, marker, etc. it will get washed out when parts are put through the cleaning/sanitation process.
- Fiber laser : makes a brownish burned outline of the lettering with slight engraving. Text size smaller than say 12 point is very hard to read because the brownish burn does not have sharp edges, etc.
- UV Direct Jet Printing : makes for a beautiful full color marking, but the marking can easily be scratched off with a fingernail. I did not test it yet in alcohol or bleach cleaning, but I would imagine it would not hold up.
- Continuous ink jet printing with solvent based inks. The ink looks nice and dark black on the white HDPE, but you can easily wipe the marking off with any sort of alcohol based cleaner, etc. I highly doubt this would last through the cleaning/sanitation process.
From my research the only good solution I have found thus far is to use a UV Laser at 355 nm wavelength. These results look great for permanent marking but problem is, these lasers start around $60k.. ouch!!!
http://www.dpss-lasers.com/Downloads/Marking%20HDPE.pdf
If anybody has any other suggestions or pointers such as pre-treament of the HDPE or post-treatment after marking I would be very grateful to learn. Thanks so much!
