585,715 active members*
3,718 visitors online*
IndustryArena Forum > Community Club House > Amada octo problem
    Aug 2013
    Amada octo problem
    Hi ,
    I have an Amada Octo cnc punch press that will not start, I don't have all of the schematics but am tracing it out.
    I can see a driver board that is located under the power supply has a green led lit up and when I press the start button a red led alarm comes on and everything shuts down. There is a small 6 pin plug going to the power supply if I disconnect that plug the unit will start but without any output from the power supply. None of the fuses are blown and sometimes if I press the start/stop buttons repeatedly the machine will start only to fault out again.
    Tom
    Apr 2008
    17
    That is almost always the power supply board. You can disconnect the machine cables to the control to make sure just in case.
    Hope this helps,
    Tom
  1. PROBLEM WITH FANUC 6M on Amada Coma
    By cristalex_it_sr in forum Fanuc
    Last Post: 08-28-2019, 07:50 PM
  2. Cutting Conditions Problem, Amada Machine
    By iBernali in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 01-04-2013, 11:35 PM
  3. Amada III 357v Problem
    By nak1411 in forum DNC Problems and Solutions
    Last Post: 11-22-2011, 02:06 PM
  4. controller file for Amada Octo
    By swift in forum Fanuc
    Last Post: 09-05-2010, 03:44 PM
  5. Amada Fanuc 0L problem laser
    By rick_7037 in forum Fanuc
    Last Post: 12-16-2006, 09:48 PM
