586,005 active members*
5,111 visitors online*
Thread: CL 20A
    Apr 2012
    34
    CL 20A
    I have a CL20A with 16T . for some reason my machine dose not detect memory card, so to change the s ram i wrote down all the data and changed the card. while writing down i dint no that there is data in side pmc dat. when i put back everything i have it is giving a alarm as specific parameters are cleared. so i need this to run the machine. PMC>DATA>Gdata
    some one pleas help
    Feb 2009
    6028
    There is also keep relays, timers and counters in that side. Gdata will only help somewhat. You will need the others as well. I don't have that data, since that machine was before we all had laptops to back up machines during install. Mori did send a hard copy with every machine in the electrical cabinet door.
    Apr 2012
    34
    i even have the timer counter and the keeprealy also . in data alos i have the group details Attachment 195634but i dint no that there is more data when i press the soft key GData. all i need is parameters in pmc>data>gdata Click image for larger version.
ID:	195636Click image for larger version.
    Feb 2009
    6028
    Ok, then. I do believe a cl15 or 25 with the 16/18 should work for those. If you have the ladder manual, default data is in the back. You will probably need to do a custom button-95-input to put them in as the ladder numbers.
    Apr 2012
    34
    the only have a copy of the electrical Manuel. any way ill recheck once more. thank you for the tip
