Hope this can help somebody in the future...
LinuxCNC, DQ542MA drivers and DB25-1205 BoB (from Wantai Motors)
When setting this up I had problems to find examples so I thought I might share what worked for me.
Based on this image I found while searching I did the wiring (not mine picture).
http://img195.imageshack.us/img195/9451/sitemanuevo.jpg
The third red form the top that goes to ENBL + is connected to pin 16.
Dip switches on the driver card are set for 200 steps/rev and 1/8 microsteps
In LinuxCNC config I set:
Driver timing: According to what is documented here LinuxCNC Documentation Wiki: Stepper Drive Timing
Parallel port setup:
Pin 2 - XStep
Pin 3 - XDirection
Pin 16 - Amplifier Enable (I will connect all drivers "ENBL+" to this pin. This will be a three axis setup for a mill)
X Axis Setup.
Motor steps revolution : 200
Drivers Microstepping: 8
Anders
Spånga, Sweden
