585,981 active members*
4,208 visitors online*
    Aug 2013
    4
    laser tube fires only with test button!!
    im trying to make my laser tube on/off using z axis dir (controlled with mach3).
    when im pressing the test button on the power supply there is red led turning on.
    i wired z axis dir to the high ttl on the power supply and when z axis, and when z axis goes down the led turning on, and if z axis goes up the led turns off.
    i guess that the signal is ok but still the laser tube not fires!!!
    please HELP me!!! i attached wiring diagram.... and im sorry for my english
    Jan 2008
    1529
    For those power supplies I think you need two inputs. The PWM and trigger. I can't tell you exactly as I have an analog supply and use LinuxCNC. However you may find useful information about the wiring if you search for LinuxCNC (the wiring will be the same)
    Aug 2013
    4
    thank you for your help...
    i tried to find info about the wiring but not someshing that helps....please if you can give more directions, meybe to change to analog power supply???
    im realy thankful for anyone who helps...and im sorry for my english
    Jan 2008
    1529
    I did a quick google.
    Some info:
    DC-K40 Laser conversion issue
    laser setings
    The Laser Project.
    I wouldn't change to an analog power supply, once you get yours going to will be much better.
    However, read your post more. It sounds like a problem connection to the laser. Can you get the laser to fire at all? So an LED on the powersupply comes on when expected? Check the high voltage and ground connection to the laser.
    Can you take some photos of your wiring please.
    Hi Larry,
    Have a word with these guys
    OPLaser support forum ? View topic - What the hell is mach3 and g-code?
    and your English is fine
    cheers
    Dave
  1. Method of finding problem if no laser & PSU has no test button
    By Melody-gweike in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 06-28-2013, 11:42 PM
  2. Help with K40 Moshi Board - Laser On with Test Button but off when running
    By techrat in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 04-17-2013, 02:03 AM
  3. Reusable CO2 100W 130W 150W Laser Tube ? Replace the traditional CO2 laser tube
    By dianmanlaser in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 04-03-2013, 05:04 AM
  4. Laser fires on "Laser Test", but not from software
    By SimonArthur in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 06-18-2008, 08:32 PM
