585,949 active members*
4,415 visitors online*
    Jan 2010
    321
    Opinions on vmc10
    Hi guys.
    Going to look at a 1995 vmc 10 tomorrow with a 88hs control. Has r/tap. 7500rpm spindle.
    Are they a good machine. ?
    Basically looking for the next step from my retrofitted knee mill.
    Will be doing small amounts of 3d in ally will the control handle it ?
    Other than that it will be just used to make ally m/bike parts.
    Anything in particular I should be looking for?
    Opinios please
    May 2013
    128
    Yes , It is a rigid and Good Machine . Your Choice is perfect.
    Jan 2010
    321
    Ok I went to check it out. Seems like a good thing.
    I will have to remove the z axis servo to fit into the garage. What is involved in removing and installing the servo it looks as simple as a few bolts but is that the case?
    Jan 2004
    3154
    Make SURE TO USE THE HEAD BLOCKING PROCEDURE IN THE MANUAL (including locking the counterweight!)
    Other than that, when you remove the servo, mark the coupling so that you can reinstall in the same position.
    www.integratedmechanical.ca
    Jan 2010
    321
    Sounds easy enough then. It comes with 3 manuals of different sorts so should be able to sort it out.
  1. DNC Drip Feed CNC88HS VMC10-15
    By BasuraBlanco in forum Fadal
    Last Post: 01-14-2013, 01:16 AM
  2. Replies: 15
    Last Post: 10-05-2012, 01:20 PM
  3. Looking for Opinions
    By wildseyed in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 01-23-2012, 11:10 AM
  4. Fadal 15xt/vmc10 spindle
    By NaRbO in forum Fadal
    Last Post: 04-02-2008, 12:59 PM
  5. Opinions
    By CharlieC in forum OneCNC
    Last Post: 07-06-2005, 07:11 PM
