585,922 active members*
3,784 visitors online*
IndustryArena Forum > CAM Software > Mastercam > Add comment in header?
    Jul 2013
    42
    Is there a place in Mastercam to add tool notes or setup notes that will carry into the post? I like to print the header so that I can get the tools loaded and I'm also writing the origin and notes, etc. on that same paper. I'd like to just type it into MC and have the program shoot it through, is that possible?
    Dec 2008
    717
    Given the nature of your question it leads me to believe that each of these comments will be specific per the program so why not just use a toolpath/manual input as the beginning toolpath and write anything you need to there?
    Tim
    Jul 2013
    42
    That is genius and I can even select to output it as a comment. Thanks!
    May 2012
    180
    You can get the post to ask for inputs at runtime. But you would have to re type out every time you post. (Like I do)
    Might be able to do it with the misc values, but don't think it would be flexible.
    I will have a play to try and find something as I would find this useful too.
    If someone knows how please give a hint.
    Sent from my HTC One using Tapatalk 4
    Jan 2010
    107
    I always use the Manual Entry for text about setup and stuff!
    Works like a charm for ISO Codes aswell!
  1. Predator header!
    By Machineit in forum BobCad-Cam
    Last Post: 06-20-2013, 04:55 PM
  2. looking for the name of a type of header
    By Smertrios in forum CNC Machine Related Electronics
    Last Post: 03-13-2013, 05:51 PM
  3. What does this all mean in Lathe header?
    By nate in forum BobCad-Cam
    Last Post: 12-11-2012, 11:13 PM
  4. Pin out for Header
    By Mr. LocoMartin in forum Stepper Motors / Drives
    Last Post: 12-08-2009, 04:32 AM
  5. Need header tubes bent
    By RickDLance in forum Bending, Forging, Extrusion...
    Last Post: 02-16-2008, 04:57 AM
