584,861 active members*
4,717 visitors online*
Results 1 to 7 of 7
    May 2013
    9
    Purified water vs. distilled water vs. deionized water
    Hi all,
    We are installing a new YAG laser from China. It’s 650W output and requires 180 liters (approx. 50 gal) of pure, distilled or deionized water for cooling according to the manual.
    Question
    • What’s the difference between the 3 types of water? Which one is the best?
    • Online search shows that I can get 50 gallons of deionized water for $380 at ChemWorld.com while distilled water for $70 from Crystal Springs Bottled Water | Delivery Service ($7/5-gal bottle).
    • Can I use water from my home Culligan water softener? We run it thru reverse osmosis filter.
    • If deionized water is a must where can I buy it? We are in northern New Jersey.
    Thanks.
    Jan 2006
    2985
    I highly doubt you need deionized water and it may even be detrimental.
    Deionized Water - Application Note - Lytron Inc
    You can buy distilled water at the grocery store for something like $1 a gallon. We use it in our chillers here (the ones that don't use Dowfrost) with an added inhibitor to prevent growing slime.
    Matt
    Feb 2009
    6028
    While we have a couple lasers that require DI water, most just want steam distilled water. Di water is actually bad for a lot of stuff, including your health!
    Sep 2006
    I used to work for fuji photo film in edison nj and they made a deionizing unit called an FRSS unit which you would pour water into and it would filter and deionize it if you are going to be using you setup often then it might be worth your while to obtain one it only uses a single D size battery if memory serves me. you could probably pick up one cheaply. any photographic suppliers should carry them as well. good luck
    Feb 2009
    2143
    According to Wikipedia, one method to deionize water is to use RO...
    "The process of reverse osmosis can be used for the production of deionized water."
    Reverse osmosis - Wikipedia, the free encyclopedia
    CAD, CAM, Scanning, Modelling, Machining and more. http://www.mcpii.com/3dservices.html
    May 2013
    9
    Thank you so much for the advices. Didn't know deionized water can be so corrosive. I will stay with distilled water for now and it's way cheaper and accessible too.
    Good nite!
    Nov 2008
    382
    Hi there
    be carefull with destilled water from publix or wallmart, I had a few gallon standing as reserve for about two month just took a bit out of one and closed it tight and as I wana take them again for exchange the cooling water for the laser again it showed a brownish settlement at the bottom its like murky.
    since then I allways just use R/O water from my R/O system.
    greetings
    waltfl
  1. Water cooled 2.2 KW Spindle water fitting
    By dfmiller in forum DIY CNC Router Table Machines
    Last Post: 11-26-2013, 06:21 AM
  2. Distilled Water for Coolant?
    By brow318 in forum Tormach Personal CNC Mill
    Last Post: 06-26-2013, 12:21 AM
  3. Request of water quality for Sino water jet cutting machine
    By Sino-waterjet in forum Machinery Manuals / Brochures
    Last Post: 03-22-2013, 02:18 AM
  4. Water jet glass cutting ( water jet seller)
    By sizala in forum Waterjet General Topics
    Last Post: 03-17-2012, 12:59 PM
  5. Water transfer techniques for water table?
    By Knut in forum Waterjet General Topics
    Last Post: 02-02-2007, 04:52 PM
