Check the working condition of the machine.
https://www.youtube.com/watch?v=TRFJ3HFQwA8
Please find the technical specs of the machine below.
The Machine is in good working condition with warranty and Manuf. year 2012 and machine is in Europe.
The technical specifications are below,
Diameter of Spindle 130mm
Taper of Spindle ISO-50
Range of Spindle speed 3000rpm
Rated Power of Main Engine S1/S6 37/56 KW
Travel Table X 5000mm
Headstock Vertical Travel Y 3500mm
Longitudinal Travel Z 2000mm
Extension Spindle Travel W 730mm
Operating Feed X, Y, Z, V 8000mm/min
W 6000mm/min
B(Rotary Table) 1.7rpm
Max. Table Load 20000kg
Table Dimension 1800x2200mm
