586,024 active members*
4,385 visitors online*
IndustryArena Forum > MetalWorking Machines > Hyundai Kia > Max RPM for threading? HIT-18S, My first thread is off in pitch. Why? Siemens 840C
    Aug 2008
    93
    I'm cutting 1/2-13NC threads and was using 500 RPM. Threads were looking really bad. Torn/Ruff. Went up to 1000 RPM and finish improved but the "nut" would not go on, PD (pitch diameter) was correct with 3 wire measurement, insert was not broken and OD was good. This drove me nuts for over a hour until I found the pitch was off for the first thread. I moved the start point away in plus Z by 1/4" and the problem went away. Seems the machine just needs more time to sync up. Am I going too fast? Does the spindle need some type of speed calibration? No mention of max speed in the manuals I have. This is a 1995 machine with the Siemens 840C control. VER 4. I think I would like to even go faster, what's the limit?
    Aug 2012
    63
    What are you cutting with? Threadmill, regular Tap, Roll form Tap ??
    Aug 2008
    93
    Lathe, single point carbide insert. using L97 cycle.
    Jul 2004
    100
    Randy,
    I will be watching this thread since I am soon to cut my first threads with my 18S.
    The program guide 2-11 give forumlas for calculating the initial start and end points for threading.
    The example at the back of the guide gives a 3mm run in and run out for a 1.5mm pitch thread.
    Looks like I might have some trouble threading against a shoulder.
    Regards, Ray
    ​"There is no such thing as a gun free zone."
    Ray Brandes, Ray-Vin.Com, PCB, FL 32408 USA
    Aug 2008
    93
    I use 0 run in and 0 run out. I set my tool to the side not the center of the point. So up to a shoulder I just program in the Z minus .010 or .020" I have done threads to a shoulder with and without an undercut at the end. If you are using an 1/8" wide insert you can thread up to about .080" of the shoulder. Did not run into problems before now, And I found an old program with 1000 RPM programmed in and that worked. Not sure why I had this problem. Let me know how fast you can go.
  1. Siemens 840C
    By lesarcs in forum SIEMENS -> Sinumerik 840C
    Last Post: 01-13-2012, 08:19 PM
  2. Siemens Sinumeric 840C
    By bandy in forum SIEMENS -> Sinumerik 840C
    Last Post: 08-05-2011, 02:17 AM
  3. DNC In Grob BS 40S (Siemens 840C)
    By shahid@cadem in forum DNC Problems and Solutions
    Last Post: 03-04-2011, 07:39 AM
  4. Siemens 840C control
    By Sniperx in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 01-26-2011, 07:56 PM
  5. Help with power for Siemens 840C
    By dfstrasser in forum CNC Machine Related Electronics
    Last Post: 05-19-2010, 11:29 PM
