Looking to setup my first CNC router (mechanical not quite done yet) with LinuxCNC and had a question for the setup on each axis in Stepconf.
What I would like to do is have the CNC home to the front left of the machine and the z axis near the top. I will have limit switches on both end of travel for all axis and want to use "Both Limit + Home" setup to use the limit switches as home switches. I also want to set the "soft limits" so that the LinuxCNC stops the machine before encountering the switch in normal operation. (ie if I jog all the way one direction I will encounter the soft limits before the switch)
Looking at the what values I should use for Home Location, Table Travel, and Home Switch Location in Stepconf (see circled in red below)
Attachment 197200
My thoughts are setting it up as shown in the attachment below
Attachment 197204
My switches will trigger approx .04" from each end travel for all axis. I picked my "Home Location" numbers arbitrarily close to the end of travel.
Does this all make sense? Is a "Home Switch Location" outside of the "Table Travel" allowed? Or is there a better way of accomplishing the same thing?
Thanks so much in advance!
