585,585 active members*
3,820 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > Has anyone machined Steel with their CNC Router?
Page 2 of 2 12
Results 21 to 22 of 22
  1. #21
    Dec 2007
    2134
    Re: Has anyone machined Steel with their CNC Router?
    Having good tooling certainly helps one get a better result, but it doesn't matter how good the tooling is, if the machine doesn't have the mass and rigidity machining steel requires, those expensive cutters will just be chattering and skipping all over the place, destroying the nice sharp edges.
    cheers, Ian
    It's rumoured that everytime someone buys a TB6560 based board, an engineer cries!
  2. #22
    Apr 2006
    1016
    Agree machine needs good rigidity but at 9000 rpm... average tooling will burn up .
    Your avg hss and carbide cutters need lots of coolent and are not designed to cut at 9000rpm.... bamboo and coolent don't mix well.
    Sent from my SM-T810 using Tapatalk
Page 2 of 2 12
  1. RFQ Small Steel Machined Part
    By Mlewin in forum North America RFQ's
    Last Post: 10-28-2013, 09:26 PM
  2. 5.5' x 10' steel router
    By j.smith in forum CNC Wood Router Project Log
    Last Post: 10-31-2012, 04:09 AM
  3. RFQ - CNC Machined Steel & Aluminum Part
    By HighCaliber in forum Employment Opportunity
    Last Post: 07-21-2010, 07:38 PM
  4. making a steel female die from CNC machined male die?
    By xaco in forum Diemaking / Diecutting
    Last Post: 07-02-2010, 10:20 PM
  5. Replies: 1
    Last Post: 05-08-2009, 09:15 AM
