585,959 active members*
4,650 visitors online*
    765
    StickFont Editor v1.15 is now available
    StickFont Editor v1.15 Release Notes
    August 18, 2013
    Fixed a problem with the startup splash window. It was possible for this window to appear off-screen making the application appear to be locked up when started.
    Scott
    Jul 2003
    Re: StickFont Editor v1.15 is now available
    mmmmm I purchased the StickFontV2 today and it has the same frozen startup splash window making the application appear to be locked up when started
    Program is unusable as it is Im at a loss to know what to do here?
    765
    The splash window that you were seeing had appeared because StickFont had been told to check for a network license server. By changing a registry setting we were able to turn this off and get your software up and running, but I am still investigating what could have caused the splash screen lock up. If anybody runs into this I would be interested in hearing about it...
    Scott
  1. StickFont v2.4 and StickFont Editor v1.5 now available
    By MetLHead in forum NCPlot G-Code editor / backplotter
    Last Post: 12-23-2013, 08:58 PM
  2. StickFont v2.15 now available
    Last Post: 09-02-2013, 03:28 PM
  3. StickFont v2.12 and StickFont Editor v1.01 now available
    Last Post: 08-08-2012, 05:19 PM
  4. StickFont Editor BETA available
    Last Post: 03-07-2012, 07:00 AM
  5. StickFont v1.1 now available
    Last Post: 07-25-2010, 03:51 AM
