585,665 active members*
3,808 visitors online*
IndustryArena Forum > CAM Software > Dolphin CAD/CAM > Dolphin Lathe: Threading finishing path not working
    I tried to cut a thread using two roughing and two finishing passes.
    This is the result:
    first roughing pass:
    N80 G32 X4.35 Z-10.0
    second roughing pass:
    N100 G01 X4.08 Z0.085 F1.5
    first finishing pass:
    N125 G01 X4.08 Z0.085 F1.5
    second finishing pass:
    N150 G01 X4.08 Z0.085 F1.5
    The second roughing pass already cuts the full depth.
    Both finishing passes are doing nothing, just moving at the same X.
    The attachment contains the Dolphin CNC file and the G-code file (latest Mach3 PP).
    The simulation already shows that the finishing passes are just cutting the old path.
    Any solution, or what am I doing wrong ?
    Harry
    Feb 2007
    412
    Hello,
    I'll take a look and see where the problem lies.
    ATB
    Andre
    thank you, Andre
    Feb 2007
    412
    Hello Harry,
    Sorry for the delay, here is the explanation of what it's doing.
    One thing to bear in mind is that the finish pass was previously called a "spring" or "chasing" cut.
    If you have a thread depth of 5mm on a 20mm bar with 3 roughing cuts, you will get the depths 20, 17.5 & 15 - this will cut the required thread, if you add a finish cut you will get a further cut at 15 to "finish" the depth, this will take out any "spring" in the tool or workpiece.
    Adding further finish cuts will only result in more passes at the final depth, this could be required for very tough materials.
    Hope this clear.
    ATB
    Andre
  1. Romi/Bridgeport EZ-Path Lathe serial transfer using EZ-Path Utilities
    By Moscow in forum Bridgeport / Romi Lathes
    Last Post: 06-04-2017, 04:37 AM
  2. Threading cycle in 0i-td not working
    By Harmeet in forum Fanuc
    Last Post: 05-19-2013, 09:25 PM
  3. Dolphin Demo / Dolphin Sales / Dolphin Support
    By Dolphin USA in forum Dolphin CAD/CAM
    Last Post: 10-28-2012, 05:28 PM
  4. lathe threading working
    By ljd10 in forum Mach Lathe
    Last Post: 04-21-2011, 03:33 PM
  5. Power Path 15 Ext. Threading
    By bink in forum Bridgeport / Romi Lathes
    Last Post: 03-19-2010, 05:15 PM
