Hoots Mon !
Is it possible to take part of an image and convert it to a dxf file or file compatible with autodesk to engrave on aluminum on a tormach
Try this.
Can anyone convert this to a dxf?
http://cdn.superbwallpapers.com/wall...-1680x1050.jpg
che
Thank you
Adam,
Very kewl, what type of machine are you using?
How thick and type of material can you cut?
Awesome work!
Jeff...
Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
Snail dxf, but it is a mess.
You might be able to tidy it up but you will need a couple of hours.
Good luck.
What software do you all recommend using to convert pdf's do dxf or dwg? I have two sketches I need converted.
Thanks in advance for the help!
MidwestJeff,
Inkscape is decent and you cant beat the cost, its open source.
Draw Freely. | Inkscape
There are several tutorials on YouTube
https://www.youtube.com/watch?v=gdWWYZ27U-k
Tutorial starts at the one minute mark.
Welcome to the Zone,
Jeff...
