585,996 active members*
4,722 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > Share Your Files Part or Art
Page 519 of 587 19419469509517518519520521529569
Results 10,361 to 10,380 of 11733
  1. #10361
    Feb 2007
    4553
    Re: Share Your Files Part or Art
    Quote Originally Posted by fortyeight View Post
    Been trying to convert a picture like this to a usable drawing with not much luck, my nephew loves the senetors, would like to make him an led sign.
    wondering if someone could help me out with this
    Attachment 263026
    Fortyeight,
    Please make sure you post an image of your finished project.
    Jeff...
    Attached Files Attached Files
    Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
  2. #10362
    Mar 2014
    109
    Quote Originally Posted by jalessi View Post
    Fortyeight,
    Jeff...
    Thanks jeff, i sure will post a pic
    thanks again
  3. #10363
    Mar 2014
    109
    Fortyeight,
    Jeff...
    hey jeff
    here is the result, looks nice, I think he will really like it.
    thanks again
    fortyeightClick image for larger version.
  4. #10364
    Feb 2007
    4553
    Fortyeight,
    Awesome work!
    Will it be used as a night light if not what is the purpose?
    Jeff...
  5. #10365
    Sep 2014
    27
    Thanks for all the help guys, can anyone get a DXF of this logo?? My buddy wants me to make a LED edge-lit sign for him
  6. #10366
    Sep 2014
    27
    it doesn't need the boys shadow or the pontoon restoration part. Here is one I did awhile ago. Simple but looks good
  7. #10367
    Sep 2014
    27
    Sorry to ask for so many favors, but I wanted to make a sign for my buddy's parents. Any help with this would be great.
  8. #10368
    Dec 2014
    187
    Hello, I haven't done this before so 90% sure its not correct. But thought I would give it a Go so next time I can improve and help those hard workers who give up their time to help us all. I guess it would make more sense to re-type any wording if a matching Font can be found? Let me know what needs correcting and I will give you an updated file.
    Ken
    Attachment 263320
  9. #10369
    Sep 2014
    27
    I tried to open the DWG and nothing was there
  10. #10370
    Mar 2014
    735
    Jalessi - I didnt see that you responded to my request until now. Thank you very much. I used a different dxf file to make this oak plaque. A friend of mine at work is going to mount his deer rack on it. Its engraved with the year over toward the right side. He's still waiting on the taxidermist so i dont have a finished pic yet. Ill post one when he gets it. Until then ...
  11. #10371
    Feb 2007
    4553
    Quote Originally Posted by J10bucks View Post
    J10bucks,
    Please do us a favor and post a image of your finished project.
    Jeff...
  12. #10372
    Jan 2008
    75
    Angry Walleye LED edge lit sign for the ice fishing house.
    Attachment 263962
    Ferny.
  13. #10373
    Mar 2006
    38
    Ferny
    What cutters were used in the fish? Was it V carved or follow the line?
    Grandpa Jay
  14. #10374
    Dec 2011
    11
    Thx jalessi
  15. #10375
    Oct 2011
    69
    how did you make your base can you explain how you did it and what lighting did you use
  16. #10376
    Jan 2008
    75
    Grandpa Jay, I just V-Carved the angry walleye with Aspire. I had to put an extra offset vector around the whole thing to get the look I wanted. I think I used a 60 Degree V-bit .625" diameter .125" depth of cut 20 Inches per minute 10" per min plunge speed, RPM speed #2 big Porter Cable router. It could have been a 90 degree .5" bit I can't remember? Those speeds worked for me. You just have to make sure you don't cut through the thin polycarbonite (Lexan) if you scale it larger or you can cut to a flat depth smaller than your plastic thickness. I have a couple air nozzles blowing right on the bit to keep from melting plastic. Make sure the swarf is flying off in small chunks instead of melting and pushing off. I keep the protective wrap on both sides until inserting into base since it scratches easily.
    For the LED base I used cuttable LED strips that come off a long reel. I think they come in 3 meter (~15') lengths from Ebay. You can cut them to length every third LED to whatever length you need. I cut a blind Dado on the CNC into the base 2X4 wood. I soldered the wires to the LED strip and stuck it to an aluminum sheetmetal heatsink. I then hand drilled holes into the dado to feed the wires through the base to my wall mounted 12 Volt power supply.
    I used the Angry Walleye on the cabinet and flasher shelves I made for the fish shack too. I'm sensing a pattern here
    Attachment 264012
    Remember to post a pic if you make something.
    Good Luck,
    Ferny
  17. #10377
    Jan 2008
    75
    V.F.W. POW MIA
    Veterans of Foreign Wars (V.F.W.) and Prisoner of War Missing in Action (POW MIA) vectors.
    I had a hard time finding these anywhere so I did them for a recent project.
    The V.F.W. vector needs some more work if you want to make it larger. Mine was 3.5" so I didn't worry about too much of the fine detail.
    I can't seem to get the hang of Inkscape so I did it in Aspire and it took a few hours to get it this good so I'm done.
    Spray painted select grade spruce/pine/fur from New Zealand makes for some decent looking two tone carvings
    Attachment 264014
    Ferny.
  18. #10378
    Jan 2015
    Looking for a skull or reaper DXF file. Thank you
  19. #10379
    Sep 2014
    3
    If possible, looking for a barbell or weightlifting theme dxf file. Thank You1
  20. #10380
    Jan 2015
    12
    Quote Originally Posted by AMolaro View Post
    Nothing spectacular, but here's one.
    Attachment 264312
    Weightlifting.dxf
  1. Share your 3D Carving files, Parts or Art
    By yohudi in forum WoodWorking Topics
    Last Post: 11-17-2016, 08:42 PM
  2. Lada
    By multiple in forum MetalWork Discussion
    Last Post: 01-18-2014, 11:00 AM
  3. Lets Share!!!!! (cut files)
    By Dustin407 in forum Waterjet General Topics
    Last Post: 08-24-2011, 11:46 PM
