584,858 active members*
4,592 visitors online*
IndustryArena Forum > CAM Software > Rhinocam > changing default settings
    1206
    I have inherited the job of programming a CNC router using Rhino and Rhinocam.Quite impressive software-but.......it frustrates me enormously by reverting to the original parameters for almost everything even when using the same type of machining operation within a single object.For instance the stock alignment always reverts to centred and top surface.The pocketing toolpath always goes back to the same stepover setting even when selecting a different set of features within the same operations browser.
    Is there a way to impose my preferred settings and have them memorised?
    1206
    Everybody else using Rhinocam must be happy withthe way they have their systems set up.I had hoped to be able to set the software to suit my working practices rather than accepting the defaults.
  1. overiding default settings
    By Pete M in forum Surfcam
    Last Post: 10-21-2012, 04:48 PM
  2. default depths not changing
    By hatchmar in forum BobCad-Cam
    Last Post: 07-18-2012, 01:12 PM
  3. Sinumerik 810M changing default settings
    By ignace in forum SIEMENS -> GENERAL
    Last Post: 10-07-2010, 05:18 PM
  4. Preferences / settings default
    By DIFF OVER in forum BobCad-Cam
    Last Post: 09-06-2010, 09:26 PM
  5. Mastercam 9.1 default settings
    By Fatty in forum Mastercam
    Last Post: 06-29-2006, 05:04 AM
