585,737 active members*
4,812 visitors online*
IndustryArena Forum > MetalWorking Machines > Hardinge Lathes > Hardinge CHNC II Flatbed Lathe lube pump alarm
    Jul 2012
    9
    Quick question about our Hardinge CHNC II Flatbed Lathe. Do you know how to purge the lube pump? Installed a new pump and need to pump oil thur the system. Keep getting an lube alarm(Lube pump failure). Do you hold down the start button?
    May 2013
    128
    Dear Sir
    What is the CNC control ? you have to check the Level Switch of Lube Pump it is in NC or not ? Next , If you can tell the exact CNC control Model , Than Troubleshooting will be better as i recall from my service Experience it is Fanuc 15 Control with Color CRT .
    Please confirm
    Regards
    Jul 2012
    9
    Got it repaired, but thanks for the reply. Control was Fanuc GN- 10F. Yes old. The only way is to turn on & off serveral times. Learned this from a call to Morris South. My problem ended up being low air pressure. Installed a new air regulator that was behind the front panel just for the lub pump.
  1. Hardinge CHNC lathe w/ Allen-Bradley 3246 processor
    By rkdygert in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 08-27-2014, 05:58 PM
  2. hardinge chnc II super precision lathe
    By brucesu1 in forum Hardinge Lathes
    Last Post: 12-20-2010, 01:02 AM
  3. Value of a Hardinge CHNC lathe?
    By Jim Caudill in forum Hardinge Lathes
    Last Post: 04-05-2010, 10:54 AM
  4. Hardinge CHNC 4-16C Alarm 2009
    By Billet Sean in forum Hardinge Lathes
    Last Post: 03-18-2009, 11:16 PM
