586,009 active members*
4,834 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > Help Removing Stuck Motor Pulley
Results 1 to 6 of 6
    Oct 2011
    141
    Anyone have tricks on removing a stuck motor pulley? The shaft on my mill motor has a keyed slot and retaining ring. As I try to pull off the pulley I believe that it is getting stuck on the sharp edge of the retaining ring grove. Would trying to heat up only the pulley with a mapp gas torch help? Other suggestions?
    Thanks!
    Apr 2005
    861
    Use a puller. And maybe some Plus Gas.
    LongRat
    www.fulloption.co.uk
    Oct 2011
    141
    Tried grinding the jaws of a cheap Harbor Freight puller to fit but it just kept slipping out. My feeling is I'll have to keep modding the puller until it just works.
    Aug 2004
    3215
    I have used a propane torch to heat and expand the pulley.
    Joe
    www.joescnc.com
    joecnc2006 at yahoo
    May 2010
    4
    Take a small round file and run it lightly around the snap ring groove. This will slightly bevel the edges so the pulley can't catch. Dont go very heavy so the snap ring still has square shoulders to seat on.
    Oct 2011
    141
    Heating up the pulley did help and I was able to get the jaws of the puller underneath the pulley. However, the pulley is really stuck now. I should have beveled the snap ring grove as suggested but too late since I chipped a tooth off the pulley with the puller.
    Worried about damaging my motor so I just decided to get another pulley for $17. Will end up Dremeling off the old pulley.
    Thanks for all the suggestions.
  1. Replies: 3
    Last Post: 04-25-2011, 02:38 PM
  2. Removing IH 3HP/3PH motor
    By georgebarr in forum Charter Oak Automation Support Forum
    Last Post: 03-30-2010, 06:54 AM
  3. Removing Spindle motor.
    By skullworks in forum Charter Oak Automation Support Forum
    Last Post: 08-31-2007, 08:19 AM
  4. Removing pulley from Taig spindle
    By warpedmephisto in forum Taig Mills / Lathes
    Last Post: 04-02-2006, 10:53 PM
  5. How to removing a pulley from a motor ??
    By RotorRouter in forum CNC Machine Related Electronics
    Last Post: 11-13-2005, 02:32 AM
