Hi! So as the title suggests, I'm looking for a CAM package for my shop.
Here's a little background. We are a job shop that (I believe) is woefully behind in terms of technology but are trying to catch up. One of the things that we are interested in is using CAD/CAM with our machine centers. At the moment, one of our milling machines is programmed with straight G-code and the other uses Mori Seiki's conversational programming interface (which is terrible). Also, at the moment we would only need 2.5d CAM capabilities.
One of the caveats is that our shop is in Japan. The reason this is significant is because computer literacy is quite low for people in machining (strange I know!) and so I'm somewhat worried that starting out with a high end program (like mastercam or esprit), as its capabilities would just go to waste for some time.
As far as CAD goes, we've tested out several and are probably going to go with SolidWorks, but we're a little lost as far as CAM goes. Does it make sense to start with a somewhat lower end program (like VisualMill) and trade up later, or would starting out with something midlevel (like SolidCam) or even high level (like Esprit, Mastercam) make sense?
Whatever the case, what are good CAM packages that would fit this situation? Ideally we would start out with something less expensive, but I also understand that sometimes you just have to bite the bullet and go for it.
Any advice would be great.
