585,712 active members*
4,131 visitors online*
Results 1 to 11 of 11
    May 2009
    327
    Vibratory tumblers
    Do you guys use vibratory tumblers at all? I have one for my small parts and love how they come out. Can't find one that is reasonably priced that is large enough to hold my larger parts. Maybe I should just save up and get a Mr deburr 300 but would love something cheaper. My longest part is about 12 inches long...
    Thanks guys!
    -Keith
    Jul 2006
    525
    Quote Originally Posted by keithmcelhinney View Post
    Thanks guys!
    -Keith
    My dads shop has a Mr Deburr 300, he's used it daily for over 15 years, and preps all of his raw aluminum in it (just to clear up the burr from bandsawing)
    I'd say its been worth the money in his case..
    Feb 2006
    7063
    Twelve inches requires a LARGE machine! I have two: One is an 18" bowl, which handles parts up to about 8-10", and one with a 24" bowl I got for $150 from a machinist who was retiring. That one could probably barely handle 12" parts. My 18" machine cost about $450, and the larger one was probably several thousand, but it's a real brute.
    Regards,
    Ray L.
    Aug 2007
    27
    check out this one from Northerntool.com it should be large enough for your parts Shop Tuff 1.25 Cu. Ft. Vibratory Deburring and Finishing Tumbler, Model# STF-18VT | Vibratory Tumblers| Northern Tool + Equipment
    Regards,
    Jose
    Feb 2006
    7063
    I did a LOT of Googling and reading before buying my first tumbler. Everything I saw convinced me the bowl-type tumblers are much more efficient and faster-acting than the drum type like the Northern Tools one. If you look into both types when they're running, you'll see a major difference in the "energy" of the action.
    It's also quite easy to build your own, the only tricky part being getting your hands on the bowl. But, replacement bowls are available, and not crazy expensive, for many vibratory finishers. The "motivator" is nothing more than a motor with an eccentric weight on the shaft. Make the size, and offset of the weight adjustable, and you can "tune" for best action.
    Regards,
    Ray L.
    Feb 2010
    119
    Attachment 201656Attachment 201658Attachment 201660Attachment 201662This is a tumbler I made from an old furnace circulator pump motor, cut motorcycle fork springs,a funnel and a feed tub. The weight is the cut stop arm from a harbor freight band saw. Any bowl can be mounted with the threaded rod.
    May 2009
    327
    I ended up ordering this bad boy
    Thumler's Tumbler Ultra-Vibe 45 Case Tumbler 110 Volt
    My really long part is actually curved so it should fit in the tumbler. I also just needed something that could handle more parts. The 12" bowl one I have just wasn't cutting it.
    -Keith
    Feb 2006
    7063
    Keith,
    Keep in mind, if the part is too large to move around freely in the bowl, it won't work nearly as well.
    Regards,
    Ray L.
    May 2009
    327
    I could squeeze the part into the 12" bowl so the 17" should be ok (I hope)..
    Mar 2011
    525
    So it doesn't really matter if the bottom of the tub is bowl shaped?
    Kelly
    www.finescale360.com
    May 2009
    327
    The part is only about 1.75" thick. Even if it doesn't work I use it for all my other parts anyway...
  1. Vibratory Tumblers
    By webgeek in forum MetalWork Discussion
    Last Post: 02-09-2011, 01:41 AM
  2. Vibratory tumblers
    By rewster in forum Benchtop Machines
    Last Post: 01-29-2011, 04:01 AM
  3. Pasts sticking in Vibe tumblers
    By Les George in forum Mass finishing equipment/media/strategies
    Last Post: 02-09-2010, 01:27 AM
  4. Tumblers Effect on Nearby Machinery
    By Crashmaster in forum Uncategorised MetalWorking Machines
    Last Post: 06-23-2007, 08:13 PM
  5. Vibratory tumblers the way to go?
    By msomerville in forum Mass finishing equipment/media/strategies
    Last Post: 01-21-2007, 03:39 AM
