Hi everyone. I hope someone can help me out. I have a torq cut 22 that the previous owner put some used motor oil or something in the way lube tank. I noticed some of the lineal ways had rust on them so I though the lube system might be plugged. I cleaned out a bunch of crud out of the bottom of the tank and put some clean oil with UV dye in it to test which circuits were not working. I have replace the oil metering units on the z axis but I can't get to the manifold for the x and y. It sits under the table bolted to the saddle right under the ball screw. When the table is all the way over I can kind of get my hand in there but I don't think I could operate a wrench enough to replace all the meters. I guess I am going to have to remove the table or something but I have no idea how. I have been trying to find a way though all my manuals and digging around in the machine. Do I have to unbolt the table from the lineal rails? Any help would be greatly appreciated.
Zane
