585,975 active members*
4,589 visitors online*
Thread: Block Window
Page 1 of 2 12
Results 1 to 20 of 30
    May 2009
    1332
    Block Window
    I have a hard time understanding the MCx5 Block window (Create / Primitives / Block)
    I click the Solids radio button and where I want my anchor to be but I can't figure out what axis the Length, Width and Height represents on the Block window
    If I have my object in the front view I would say that the Length is my X axis, the Width is my Y and the Height is my Z but following this my object is not drawn correctly.
    Any help?
    Nicolas
    Sep 2013
    131
    Creating in isometric view is easier. I just use rectangle shapes, rectangle, extrude in solids. I hope this helps. cheers.
    May 2009
    1332
    Looks like to be the easiest way, thanks for the help
    Nicolas
    Sep 2013
    131
    Sure, any questions, just ask. I'm new on here and work for Boeing.
    May 2009
    1332
    Thanks mate for the help
    Don’t know very much about MC but I design my new cnc in MCx5 and I learn as I go along
    When I stumble again I will ask
    Much appreciated
    Nicolas
    Sep 2013
    131
    Sounds good. Cheers.
    Jun 2005
    305
    It works properly from TOP view.
    You are correct.
    X is length.
    Y is width.
    Z is height.
    People with SolidWorks experience have a hard time with Mcam because the default screen is 90 degrees off from what they're used to.
    ObrienDave. MasterCam since V6. Gcode since 1983.
    The nose you punch today may belong to the butt you have to kiss tomorrow.
    May 2009
    1332
    Every time I want to exit MCx5 I'm getting this annoying message "Are you sure you want to exit MC"
    Is there a setting somewhere to disable it?
    Nicolas
    Sep 2013
    131
    It is annoying, I agree, and I'm sure there are a few ways to lose it, after all, there are a few ways to draw a line,lol. It is a good feature to have though, with all the icons everywhere, in case you hit exit by mistake. Just a thought.
    May 2009
    1332
    The other message which says "Save before Exit" is important but I thought after I save and hit exit I dont have to be reminded again if I want to exit. Not very important but I thought it could be something easy on the settings which I might have missed.
    Thanks anyway
    Nicolas
    Jun 2005
    305
    Unless Mcam has made changes to the exit routines in the last 20 years or so, then no, AFAIK, there's no way to get rid of that particular message.
    May 2009
    1332
    Thank you Dave, I have searched everywhere and cant find anything so what your saying must be right
    Not a big deal anyway but it is annoying
    Nicolas
    May 2009
    1332
    I have a hard time again to complete this task. What you see in the attached pic is my two vertical gantry pcs and a horizontal pc at the bottom.
    I want to place the bottom horizontal pc at the top of my two gantry pcs but there is no way I can do this, I mean the pc goes all over the planes but never at the top.
    To achieve this I use Transform / Translate 3D, and I click on 3 point at the source (the horizontal pc) and 3 point at the destination but my pc never goes where I want it.
    Perhaps there is a better command to get it done?
    Nicolas
    May 2009
    1332
    Got my problem resolve by trial and error
    Nicolas
    Sep 2013
    131
    I see you got it, I use translate, then from one point, and select the top corner of the part I want to move, then the corner I need it to go to. That might be what you did too. Rod.
    May 2009
    1332
    Thank you Rod, thats what I did
    Nicolas
    Sep 2013
    131
    Perfect.
    Apr 2003
    3578
    you really want to look at Dynamic Xform makes easy to pick the part and drag it in 3D space were you want it.
    Have you ever used Dynamic WCS before?
    Cadcam
    May 2009
    1332
    Quote Originally Posted by cadcam View Post
    I tried a lot to get the Dynamic Xform working for me but...no luck with it. Looks like a good tool but the MC help is useless and so I used the Translate as Rod mentioned which is so easy
    Nicolas
    Sep 2013
    131
    I'm not sure which one of us you are asking, but any info is good for everyone. I work for Aerospace, and we bring our part models in and orientate them for machining with Dynamic Xform to establish our xyz coordinates.
Page 1 of 2 12
  1. Output Window
    By programmer4fcmt in forum Esprit
    Last Post: 11-02-2011, 10:58 AM
  2. MDI Window
    By Magnum164 in forum Tormach Personal CNC Mill
    Last Post: 11-20-2010, 02:34 AM
  3. Missing Window
    By Andre' B in forum NCPlot G-Code editor / backplotter
    Last Post: 09-18-2008, 12:59 PM
  4. RS232 program block by block
    By smoregrava in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 12-22-2005, 07:52 AM
  5. Jogging window...
    By murphy625 in forum CamSoft Products
    Last Post: 04-06-2005, 12:01 AM
